Rubber Track Pads
Rubber Track Pads
Thank you received: 33
Thank you received: 251
2 years 1 week ago #240609
by juiceman
Nice. Did you buy those from John S? or did you make your own adapters, etc? I by pure luck found a set of surplus ones on FB of all places from a JD guy that did not want them; of course that was a couple years after I already bought a nice set from John. Per his comments, it should take approximately 4.5 hrs to bolt them on. He was pretty darn close!
Those sure make parading around nicer. I have driven my D2 down the road before in 5th gear and received a few stares...I have also used the tractor to disc with and pull scraper with with no issue, other than a little slippery on wet grass (even the big rubber tracked units do that)
Thank you received: 387
2 years 1 week ago #240611
they also had steel road shoes as a genuine accessory for machines drawing trailers etc on the road network.
2 years 1 week ago #240613
by 3J1Bill
Yep, I bought them from John. They fit nice and went up the paved driveway without leaving a mark. It did take about 4 hours. Also a few pictures of the factory shoes. Bill
Thank you received: 191
2 years 1 week ago #240618
by D4Jim
Nice looking 22 and parade ready!!
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
Thank you received: 6
Thank you received: 13
Thank you received: 7
2 years 6 days ago #240651
by D2Fred
how do you think these pads would compare to the ones on my d2?( check tractor picture in my avatar) would they work with some modification?
2 years 3 days ago - 2 years 3 days ago #240695
by 3J1Bill
Fred, you would need a grouser pad to bolt on these. The factory ones you have would need new rubber molded on the shoes. Like my CAT TEN does. Bill
Last edit: 2 years 3 days ago by
3J1Bill.
Rubber Track Pads
