D4 7U won’t start after moving
Thank you received: 13
2 years 1 week ago #240599
by greengiant
after going through everything else, it was the rack that was the problem with my d4 78a. cleaned it up and starts right up.
Thank you received: 118
2 years 1 week ago #240605
by Ray54
Check that the compression release lever has not been moved, unless it was removed when the pony motor was removed. I would think you would have smoke if you have fuel but check the lever anyway.
Somedays it is much more trouble to prime the pump after changing filters than others. Most times I loosen the fuel lines to bleed the pump. But one time I spent 3 or 4 hours fussing. Hauled air compressor out into the field, still nothing. Started as soon as I opened the pump bleed screws with 1/4 turn wrench that is a pain. I need the socket.
Thank you received: 387
2 years 1 week ago - 2 years 1 week ago #240612
also check the oil level in the injection pump it is the slotted bung below the rectangle cover plate. the oil should be at the bottom of the thread. it takes engine oil. if the throttle lever for the operators seat position is anything like our machine you wont get good feel from it due to wear and play. try the lever on the governor housing it should give good feel full fuel/noise is pushed to the rad as far as it will go.
2 years 1 week ago - 2 years 1 week ago #240623
by rsilva11
Something that comes to mind is they knew how to start it. Mine starts from a pony motor. there are no glow plugs so while the pony warms up a little it warms the intake manafold on the diesel and gets a bit of coolent flowing. after the pony warms a bit I engage the pony clutch with the diesel compression release on. I dont see a compression release in your pic so idk if you have one. then while the pony motor is spinning the diesel getting its blood warm and the fuel lines primed for a min I then push in the compression release with the diesel at about 1/4 to 1/2 throttle and let it try an fire. so if I was going to convert that I would have to consider that start procedure. Im assumming you need to let it spin longer before you release the compression release.
Last edit: 2 years 1 week ago by
rsilva11.
2 years 1 week ago #240638
its a fuel problem. either they arent setting the lever correctly. the rack is sticking closed, the govenor isnt allowing the rack to open fully as its fualty. there is a airlock somewhere, or the lift pump isnt lifting fuel to the injection pump properly. or a blockage some where preventing fuel flow.
the most likely are a air lock or the rack isnt opening enough. as it was running when they loaded it on the truck. it ran fine when they unloaded it. the next day wont start so that makes me think a bit of crud was loosened during the move and is causing a blockage.
2 years 1 week ago #240644
by rsilva11
Youre right. I was thinking they just bought it and never had the attempt at cold starting it.
Thank you received: 70
1 year 11 months ago #240937
by phildirt
Why do people post a question, with pictures, get 14 helpful (?) replies and then don't even indicate that they read the replies?
Death in the family? Had the computer repossessed? Death in the family? Just an asshole?
Thank you received: 620
1 year 11 months ago - 1 year 11 months ago #240938
by Rome K/G
Why do they even buy something so old they dont have a clue how to operate it?????????????????????????? "no fuel gauge but has good pressure" Doesn't know what the thing with the little window is!
Last edit: 1 year 11 months ago by
Rome K/G.
