D2 Oil Drain Plug Gasket
2 years 2 weeks ago - 2 years 2 weeks ago #240535 by Cat Yellow1
My D2 (4U1826) is leaking oil at the drain plug of the diesel engine, but I'm unable to find a part number for the gasket in the parts book.  Does anyone have a part number?  I see the plug in the bellhousing shows 2, but not sure if it is the same plug as the engine base use.  Could someone confirm?  Red arrow on the graphic.  Thanks.
Last edit: 2 years 2 weeks ago by Cat Yellow1.
2 years 1 week ago #240536 by PhilC
Replied by PhilC on topic D2 Oil Drain Plug Gasket
I would say the part number is 0L-1124 as you suspected. As far as I know all drain plugs are the same except the ones on the steering clutches.
2 years 1 week ago #240537 by gemdozer
Replied by gemdozer on topic D2 Oil Drain Plug Gasket
The plug is l-827 and gasket l -1124 same from cluh housing
The following user(s) said Thank You: Busso20
2 years 1 week ago #240538 by Rome K/G
Replied by Rome K/G on topic D2 Oil Drain Plug Gasket
0L-1124, put separated side towards plug.
2 years 1 week ago #240539 by side-seat
Replied by side-seat on topic D2 Oil Drain Plug Gasket
If it's just the drain plug all you need is a new copper washer that fits the drain plug.
2 years 1 week ago #240541 by Rome K/G
Same as the bellhousing uses.
2 years 1 week ago #240551 by Cat Yellow1
Thanks All. That's what I suspected but thought I'd check here before I ordered.
Time to create page: 0.167 seconds
