Cat Excavator Master pin
Thank you received: 42
2 years 2 weeks ago - 2 years 2 weeks ago #240528
by restore49
A Friend has a 1988 Cat Excavator 225 BLC needs to separate track to work on tensioner piston packings. Is the pin one piece or plugs in each end?? Has a divot (3/8Hole) in center on each end . Bob
Fat Dan
Thank you received: 620
2 years 2 weeks ago #240529
by Rome K/G
Does it have a rubber plug in the center of the divot? That would be SALT track and should have an "alligator" link to separate the track..
Fat Dan
Thank you received: 9
2 years 1 week ago #240582
by rturn3060
It is best not to rmove the track pin because the shock loades on ex. tracks from lifting loades that transfer enough weight to one corner sometimes can lift the rear of the machine off the ground. Driving the pin out can result in ending up with a loose pin that wants to walk back out. If you release the track tension cyl., backthe idler using the back of the bucket all the way back. Using the bucket by lifting the machine slightly and using the swing you should be able to push the track off the idler which can be slid forward and removed if necessary. Repeting the process usually requires using two chains to start the track over the idler. I have done thes on 225 and 235 excavators as well as a 500 Hitichi. Hopes this helps.
Time to create page: 0.143 seconds
