Do I have a wet clutch or dry clutch?
Thank you received: 387
Thank you received: 620
Thank you received: 14
1 year 11 months ago #240804
by G2D2
You really know your stufff, Exactly as you described it! Opened the drain and nothing. Plugged with a metal like hymen Got some light fence wire pierced it swirled around and drew back and forth 70-80 times and eventually I had about a quart of Weird looking oil and metal approx 1 dimes worth of metal sludge very fine, I used a half gallon plastic milk jug to catch the oil, brake cleaner and gas worked good !
I poured in Marcon LV until it flowed out the side level plug and then I plugged it and poured a couple ounces more I might run it for a bit and then replace it with a fresh batch of Mercon LV equivalent (low viscosity) or try mercon 3
Thank you!
1 year 11 months ago #240808
by Rome K/G
Your welcome, good to have it all cleaned out now, should work allot better too.
G2D2
1 year 11 months ago #240823
i'll have to flush mine out properly too it was working fine but 50yrs of crud is in there. so you fella's have better results with atf which is around a sae 5 weight oil.
yes they used 30 weight in everything back then as its what they had multigrade oils didnt exist and took yrs to be accepted as superior in most situations and much more convenient.
1 year 11 months ago - 1 year 11 months ago #240830
by G2D2
Unfortunately no change still grinding when I throw the first lever towards the rear, thinking those screws I found in the clutch housing drain I have a place to be..so now I guess I got a pull the pony motor, About the ring gear grinding, are we talking about the ring gear on the pony motor?
Last edit: 1 year 11 months ago by
G2D2.
1 year 11 months ago #240831
by Rome K/G
If you push back on the clutch/brake lever it should stop the pinion gear so it can engage with the flywheel ring gear. If not then the brake discs are worn out.
Thank you received: 187
1 year 11 months ago #240836
by Mike Meyer
On my RD4 I have a short bit of water pipe about 12" long sitting over the pilot motor clutch / brake lever, which gives me just that bit extra leverage to stop the pinion spinning so I can engage the pilot.
One of these days I'll pull the pilot motor off and rebuild the pinion clutch and brake plates, but in the meantime, the pilot motor starts easy and runs well, and that tractor only gets driven maybe twice, or 3 times a year, so my Okie fix is buying me plenty of time, because I know if I pull that pilot motor, it will not go back on till I've fully reconditioned the darn thing, and that doesn't make sense right now because it runs so well, and why open a Pandorra's Box that doesn't need openning......
Thank you received: 49
1 year 11 months ago #240841
by kracked1
Still confused as to what kind of grinding you are getting? Video maybe? Pictures showing first lever? I know with my D4 it will grind terrible if I forget to release the pony clutch when the main starts. If I remember the pinion slides right in quietly.
Time to create page: 0.396 seconds
