Big stuck nut
Big stuck nut
Thank you received: 103
2 years 1 month ago #239743
by Fat Dan
All great advice. Might try heat cool cycles, heat to red 400-550° then might try candle wax and let cool (map gas may not be hot enough). I weigh over 300lbs and bounced on my 1" braker bar with a 3 5/8" nut. That didn't work as well as I wanted so I gathered up a 15' cheater bar and bounced on it with everything I had until the nut was torqued to ~ tic tic pounds.😁 ~1400lbs - 1800lbs total guess. A good USA made 1' breaker bar should take the abuse.
ACMOC Membership
Thank you received: 251
2 years 1 month ago #239744
by juiceman
Yes, 18 volt Millwaukee brushless gun 3/4' can do wonders. If that does not do it alone, try the heat method. I wonder if the nut is LEFT hand threaded? Last resort would be to split that nut with a die grinder or such. It would be nice if someone familiar with that BIG nut and winch could chime in. Nothing is impossible, it might just take a little longer....JM
Fat Dan
Thank you received: 409
2 years 1 month ago #239745
My understanding is that every heat and cool cycle shrinks the object, so if that's the case, it would be preferable to just heat it up and remove it in one go, rather than letting it cool and get even tighter. I stand to be corrected though.
Fat Dan
Thank you received: 620
Thank you received: 45
2 years 1 month ago - 2 years 1 month ago #239748
by side-seat
You know, I was thinking that too about a left hand thread after I posted . Clean the paint off and take a close look at the thread and you should be able to see if it's starting counter clockwise.
Fat Dan
Thank you received: 183
Thank you received: 94
2 years 1 month ago #239753
by josh
It’s not a left hand thread, just a good size fine thread nut with a lot of tension on it, that rod is a major part of the structure on the winch, holding the drum and the cast steel housing assembly together, they are tight, I have a 2800 ft/lb spline drive impact wrench, usually have to stand there and let it whack away for a couple minutes, uses a lot of air but they always come.
2 years 1 month ago #239754
by Busso20
Hi Neil, when an apprentice we were told that 1 inch of diameter will grow 4 thou with heat (can't remember temp range for it), first heat will shrink the most and the second a little and the third generally shrink is minimal or none,
Was told by a boilermaker that heat the pin not the bush/boss/clevis so it can grow to crush tighter in the tolerance, this will transfer heat out to the bush, then cool pin only slowly to allow it to shrink pin and heat to remain in bush/boss/clevis to be expanded slightly to let go of pin, one day we heated a steering cylinder pin red hot at ends, cooled with trickle from hose and left jack under the pin to push out, we went for smoko and heard a bang, pin came out in hurry dented cab floor underside, pin out with heat and cool only(no hammer work).
Fat Dan
2 years 1 month ago #239757
by Rome K/G
True on the air, used a 1" impact to remove track bolts with two cylinder shop compressor, just didnt have the volume, got the Joy out with the D315 at 210 cfm and wulla, spun em right off.
Fat Dan
2 years 1 month ago #239759
That's pretty cool Busso, I'll have to remember that - thanks!
Big stuck nut
Time to create page: 0.184 seconds
