Anyone replaced their Button head grease fittings with Zerks Why or Why not?
Thank you received: 285
2 years 1 month ago - 2 years 1 month ago #239734
by gauntjoh
We have an Alemite catalogue and operating instructions in the Library for these volume compressors.
Last edit: 2 years 1 month ago by
gauntjoh.
Thank you received: 387
Thank you received: 191
2 years 1 month ago #239752
by D4Jim
That is good they still make the volume pump 7181. I looked at one when I picked up some grease from our distributor about 5 years ago. The pumps were rather pricey then at over $400 for the bucket less the hose so would expect to pay much more now. As i remember it looked to be considerably lighter that my old CAT Greasers!! .
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
G2D2
Thank you received: 251
2 years 1 month ago #239766
by juiceman
If you are near N. California, I can hook you up with one. I do not ship large items (sorry). Or you might share your location, and someone near you might have a reasonably priced volume pump to sell you. As far as portability, I have noticed extremely heavier older ones, VS. newer and much lighter ones. If you don't plan on a lot of greasing, just buying the grease gun adapter and tubes of 00 lube for a "one time" grease job may be your best bet. Just be sparing about the amount you provide, as to not damage your seals.
Who knows, maybe you already have a leaker or two, so not an issue? Good luck. JM
G2D2
Thank you received: 21
2 years 1 month ago #239802
by Mschwartz
Yes if you are in the PNW I can get you one. Have acquired many over the years as everyone had them around here. Still find them at sales often full of grease. Mike
G2D2
Thank you received: 14
2 years 1 month ago #239823
by G2D2
I'm In Eugene, Oregon! But I drive around a bit let me know if you have a 6521 6536 I found a parts one not sure if it will work or not yet
2 years 1 month ago #239824
by G2D2
Thanks! YESI already have filled an old t#2 tube from a 5 gall 00 bucket what a mess that was lol Ordered a old 6000 series alemite supposed to be working but we will see!
2 years 1 month ago #239830
dont phaff around trying to fill a empty cartridge, buy cartridges of the right grade. or set your gun for bulk loading. then to load remove the head from barrel wipe the thread clean with rag, stick the end of barrel just into the grease no deeper than the thread and draw the follower back sloooowly keeping the end in the grease till it locks back, carefully check how much grease has drawn into the gun, if needed get a paddle a steel ruler is good for this and pack grease into the barrel using a wipe and push method like packing wheel bearing by hand, when you think you've filled it enough screw the head on 3/4 of the way release the rod and bleed the air. the other way is to use the j2 loading port and a j2 loader pump. yes bulk is cheaper if using a lot of grease. but its easier and less mess to use cartridges. unless you've got one of those volume compressors.
G2D2
2 years 1 month ago #239844
by juiceman
Ugh! TKids88 is reminding me of my youth. My brother was adamant that we only use bulk grease to fill the one and only grease gun we owned, because cartridges cost too MUCH $. What a mess that was sometimes, when the plunger slipped and all the precious grease gurgled back out of the gun, and then you spent 10 minutes trying to get the air pocket out of it, because we were not allowed to use anything but the suction of the gun to load it with. Hahaha, fast forward, we only bought tubes of grease, then nobody wanted to reload the empty grease GUNS (I emphasize plural), so now there are a dozen hanging on the combination bolt bin/tool cart all EMPTY except for the special one he uses for his boat trailers. Glad someone has their priorities in order! LOL. JM
G2D2
Time to create page: 0.409 seconds
