3304 955L torque settings
Thank you received: 63
2 years 1 month ago #239522
by PhilC
Hello All
I am fitting a 3304 into my 955K that has the later style 955L coupling on the flywheel. As I only have the 955K's workshop manual I don't have the torque settings for the bolts in the flange. Bolts are part number 4 (1A1460) in the pic below.
Also I could not find in the manual the torque setting for the flywheel bolts.I have 118-142 ft lbs from the 944's manual. Is that the same for the 3304? Bolts are different lengths but the same diameter and thread.
Regards
Phil
Thank you received: 620
2 years 1 month ago #239536
by Rome K/G
Coupling bolt torque is 80 ft lbs
Flexible coupling flange (part #'s 6P3983,6P3984.6P5020] bolt torque is 95
Two piece front flange center bolt torque is 160 ft lbs
Dont have flywheel bolt torque, must use standard bolt spec torque.
2 years 1 month ago #239546
by PhilC
Thanks Rome but mine is a single piece flange.Do you know what size bolts are in the two piece flange?
2 years 1 month ago #239547
by Rome K/G
The bolts for the rubber couplings are 6H1717 1 1/8" 1/2" coarse grade 8
Bolts for the front flex plate are special high strength bolts 0L1329 3" 1/2"coarse
Recommend getting bolts from Cat.
2 years 1 month ago #239621
by PhilC
Thank you very much Rome
Thank you received: 45
2 years 1 month ago #239635
by side-seat
On the subject of fly wheels; we are putting a D315 back together. what is the torque value on my flywheel bolts?
We torqued the bell housing nuts to: 150ft lbs.
2 years 1 month ago #239636
by Rome K/G
Use the bolt torque setting for that size and thread bolt. No set torque ratings are given for flywheel bolts in the manuals.
