Need Help to IDENTIFY YEAR D2 Serial plate is off engine and trans Winch covers
Thank you received: 14
2 years 1 month ago #239469
by G2D2
Howdy from Oregon y'all!
I just bought a Caterpillar D2 and the engine tag is missing and the tag on the trans is hidden by the Winch.. I have seen similar ones that say they are 1951 or 1953? But I would like to know for sure and I know for sure someone here can ID it
Thank you received: 94
2 years 1 month ago #239471
by josh
In the 4th picture, you can see where the serial number tag on the engine block was, there is one rivet left and a hole for the other rivet, if you scrape the paint off between the two rivets, you may be able to see the serial number stamped in the block.
G2D2
Thank you received: 620
Thank you received: 409
2 years 1 month ago - 2 years 1 month ago #239478
The transmission at least is post 5U13273 (or the 4U equivalent) because it has the two-piece clutch shaft which would make it in the early '50s I think. I'm wavering on the dash forward though without my parts catalog because the gauges are not mounted on the separate small dash unit - I don't know when that change was made, and the governor control does not have a remote handle mounted on the governor assembly itself. The fenders are also pressed steel. I suspect the transmission and engine serial numbers might not match but only one way to find out for sure
Last edit: 2 years 1 month ago by
neil.
G2D2
2 years 1 month ago - 2 years 1 month ago #239480
The fill plug vs two bolt cover on the pony clutch housing puts it in the 47-48 era. Course it could have been changed.
The transmission shift lever puts in the late class. Looks like a hybrid mix. Can't quite see the compression release mechanism.
G2D2
2 years 1 month ago #239508
by G2D2
Neil, Great stuff Thank you!! At 5U16128, an oil clutch became standard where would I look for an indication of that?
I will have to become a Member of ACMOC if they have all the parts books in .PDF? looks like they have a good bit of literature anyway.
2 years 1 month ago #239509
by G2D2
Old Magnet, I appreciate the info! I will try and take a better photo of the compression release I know it's brass.. From what you and Neil have said I'm thinking at some point it was updated to a new tranny and some parts were swapped here and there.
Thank you!
Time to create page: 0.206 seconds
