Cover gasket help
Cover gasket help
Thank you received: 49
2 years 1 month ago #239438
by kracked1
Have the parts book but cant figure out the part number for the transmission cover gasket. It is a single piece cover D47U. Any help would be great.
Thank you received: 153
2 years 1 month ago #239439
by rax200
Hi kracked1,
The gasket you are after is 3b0889 and 2 required, but sit down when Cat tell you the price. I now use a length of 3/8 o ring material as it was much cheaper.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
kracked1
Thank you received: 387
2 years 1 month ago #239442
any thing that is a oring groove seal its cheaper to buy a length of the appropriate size nitrile o-ring stock and make your own. bond it using loctite 406 adhesive or loctite 480 rubber toughend adhesive. both are available through most good industrial suppliers or bearing suppliers. many workshops dont stock premade orings any more and use kits to make what they need as its cheaper.
Thank you received: 70
2 years 1 month ago #239444
by phildirt
The information above is not correct/ complete.
This question was beat to death several years ago on this BB.
2 years 1 month ago #239449
by rax200
Hi All,
current price for 3b0889 and you require two and in Aussie you add 10% gst
regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
2 years 1 month ago - 2 years 1 month ago #239456
by kracked1
Current Ziegler Mn price is $143.xx. I did find the gasket thread to reference the full list of gaskets needed.
Last edit: 2 years 1 month ago by
kracked1.
Thank you received: 251
2 years 1 month ago #239457
by juiceman
My very first D4 revival project required new cork seals for the transmission cover. I about fell over when I saw what the invoice was just for the cork. I vowed to use something cheaper next time, such as rubber rope, which I was able to buy an entire 300' spool of it for way less money. Some say it was not right, but it works just as well if not better for less. JM
kracked1
Thank you received: 187
2 years 1 month ago #239460
by Mike Meyer
I bought a 3/8" thick sheet of rubberized cork knowing that I had a few tranny covers to work on, and cut replacement strips out of that.
kracked1
Thank you received: 42
Cover gasket help
