Serial number and patent information tags
Thank you received: 7
2 years 2 months ago #239228
by tdalan
Going to run some serial number and patent number tags for early tractors . The price will be in the $ 135 range for the patent tag and $65 for the serial number tag . I’m just passing it along , I know they are expensive .
we are planning on using stainless steel like the originals
Fat Dan
2 years 2 months ago #239234
by tdalan
They would be without the number in them but depending on what you want it shouldn’t be a big deal to stamp it with 1/4” steel stamps or have it etched on . So maybe just a few dollars more for etching . If this helps
Fat Dan
Thank you received: 37
2 years 2 months ago #239241
by naylorbros
Hi Dave. This one was supposed to have come out of the patent office. A little earlier than the one you are looking at getting made.
Fat Dan
2 years 2 weeks ago #240467
by 1oldiron@comcast.net
I am a new guy here, and have a related question: The serial number tag for the engine block is missing on a D8 I am bringing back to life after a 25+ year rest in the bushes. It has a slide bar shift, so is anything from a 1H, an 8R, or an early 2U. Can anyone please tell me where I might find the frame location for the number? A Cat rep told me it would be front left under the floor plates. Can't see any joy there.
Thanks in advance!
Jeff Howard
Redmond, WA
Fat Dan
Thank you received: 90
2 years 2 weeks ago #240483
Thank you so much for the quick reply! I am 550 miles from the machine and am having photos sent to me. It has a crankshaft driven winch for the blade, but might have one on he rear as well, I hope I do not have to peel that off to see the number.
Thank you again,
Jeff
Thank you received: 118
2 years 2 weeks ago #240487
by Ray54
Well don't forget the engine block has the numbers too. Behind the starter pinion lever. If the tag is gone it was stamped into the block behind the tag.
2 years 2 weeks ago #240488
Well, an old fella like me learns something new every day! Thanks for the update. I'll take a brush and some Brakekleen after that area and see if I have any luck.
Thanks,
Jeff
Thank you received: 19
2 years 2 weeks ago #240489
by sheddcanyon
Are these patent tags year specific? For example, I have a 1935 Diesel Forty and the patent tag at the rear of the tractor is chewed up. Would a tag on 1935 Diesel Forty be different from a 1938 D2?
Time to create page: 0.193 seconds
