Cat 212 pony start button
2 years 2 months ago #239063
by MikeHanson
Does anyone know of a aftermarket push button type switch for the 212 pony! Mine has gone bad,maybe Napa or? Thanks MikeMike. Cat does have in stocks 85.00
Thank you received: 387
2 years 2 months ago #239069
yes go to your local parts store or electronics hobby shop such as jaycar or RS components they should have suitably rated switches the other way is to get a external starter solenoid and use the switch to control the solenoid this means the switch is only switching low current and will last much better it how its done in your car the contacts in the key switch only handle around 20 amps but the starter solenoid handles 600 or more actually many have a second relay to switch the solenoid. it just makes thing last longer.
Fat Dan
Thank you received: 153
2 years 2 months ago #239071
by rax200
There are plenty on the net just search insulated push button switch. These are the same as used on cats you will probably get one a NAPA just take it in with you.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Fat Dan
Time to create page: 0.133 seconds
