Cat D7 4T crankshaft
2 years 3 months ago #238813
by D74T
Does anyone know the minimum crank shaft diameters for a Cat D7 4T? My big end crank journal measures 89mm, at new it is supposed to be 92.075mm.
Thanks.
Thank you received: 76
2 years 3 months ago - 2 years 3 months ago #238819
by seiscat
Here is a page from the Servicemen's Reference Book for the engine used in the D7 3T it should be the same.
Craig
Last edit: 2 years 3 months ago by
seiscat. Reason: better scan
D74T
Thank you received: 387
2 years 2 months ago #238824
check your parts book for oversize bearings it will show what the max oversize expected is. yes babbit bearings can be custom cast in place to any size but you dont want to be under minimum journal dia.
also check the journals for out of round. and magnaflux tested for cracks
any good engine rebuilder should be able to rebuild that crank with flame powder spray welding and then regrind to size. it wont be cheap but it will get you back to spec.
D74T
