Blacksmithing a Thirty heatbox.
Thank you received: 77
2 years 3 months ago #238300
by Bruce P
Hi all. I recently got this Thirty and I’m in the process of putting it back together. I had repaired the intake manifold for the previous owner, but I knew the heatbox needed attention. The lower ears were broken off and the threads for the exhaust pipe were badly damaged. I decided to build my own heatbox out of iron. This is purely cosmetic and nonfunctional as I don’t intend to burn kerosene in the dead of winter, but I wanted it to look semi respectable. Here is the progress thus far.
BP.
Thank you received: 187
2 years 3 months ago #238302
by Mike Meyer
That is very impressive work there Bruce, well done, I need to find 3 sets of manifolds here for my old wrecks and am wondering how you repaired the inlet manifold too?
Mike
2 years 3 months ago #238305
by Bruce P
Thanks Mike. The intake had started to break the outer jacket off. It sort of exploded from the inside out. I took a grinder with a cutoff wheel and cut where the outer jacket was still held on and opened up some “windows” to clean out the rust and carbon that was in there. It was a tremendous mess inside. Once I finally got it all cleaned out, I brazed the windows back in.
Your pictures look like your manifolds are a little further gone than this set.
BP.
Thank you received: 48
2 years 3 months ago #238309
by mog5858
I like the way you went about it that's some great work. thanks for sharing as it helps with ideas on how others were able to fix things.
Bruce P
2 years 3 months ago #238317
by Bruce P
Well here is the finished product. Good enough for a toy tractor I’d say.
BP
Busso20
Thank you received: 620
Thank you received: 23
Time to create page: 0.206 seconds
