D315 Engine info wanted
Thank you received: 45
2 years 3 months ago #238141
by side-seat
Can anybody tell me the year or specs for 9S13218
My serial number book has just 9S as a marine engine.
Fat Dan
2 years 3 months ago #238143
Rack setting bible has the 9S5001-up as Industrial, Marine and Gen set Engines
Specs vary according to full load engine rpm.One example is 54 hp continuous at 1800 rpm.
Close as I can get is 1953-1958 for late s/n engines.
Unit was replaced by 48Bxxxx in 1959
Fat Dan
2 years 3 months ago #238144
by side-seat
Thanks OM .
This was out of most likely a 15B Bucyrus Erie.
Were going to do a transplant into our D47U I posted back a couple months ago the we dragged in. Engine took in a good bit of water sitting uncovered out in the woods. I figure it'll be much easier just swapping out parts from the original onto the power unit instead of finding a better head and put in liners. A couple jugs were really pitted bad beyond just running the ball hone in to clean up.
Fat Dan
2 years 3 months ago #238147
That will be a balancer engine with later heads that can accomodate glow plug chambers and direct electric start. It will not have the front and rear scavenge plumbing for the oil pump.
Fat Dan
Thank you received: 103
2 years 3 months ago #238150
by Fat Dan
Well I'd say that should work with little medications here and there. Please keep us informed
ACMOC Membership
Time to create page: 0.138 seconds
