- Thank you received: 13
OK easy fix, if it dose not run without choke is a good sign the low speed circuit is plugged. The Zenith carb has a brass tag riveted on the top of the carb. 5F3525rustyfender post=238081 userid=5630I am sure I am not the only one having carbourator issues with a D7 17A phoney carbourator, I have had it apart several times, it’s dirty and crappy inside, tried to clean but. It seems to be worse not better, It is still in use but takes a lot of my time and patience getting engine started only runs with choke completely on and then hardly gets enough fuel to go. Is there any replacement carbourators out there? I believe it is a Zenith no numbers anywhere I can see.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
