off topic- Killefer 15-20 pan breaker
Thank you received: 142
2 years 3 months ago - 2 years 3 months ago #238080
by bursitis
brought home a nice late model Killefer 15-12 pan breaker today. can still read the factory logo on the frame.
Last edit: 2 years 3 months ago by
bursitis.
Fat Dan
Thank you received: 44
2 years 3 months ago #238082
by GrantJ
bursitis, have you found anyplace that has information on the old Killefer implements? I have a very old Killefer that is mechanical (not hydraulic) but I dont know what it was originally used for. I also have a John Deere Killefer tool bar carrier that has a hydraulic ram but is still steel wheeled and tow behind. I have not been able to find any info on either of them. Any ideas would be appreciated. Grant.
Fat Dan
Thank you received: 251
2 years 3 months ago #238108
by juiceman
I always noticed Caterpillar crawlers pulling JD Killefer implements. I was told back in the day when dealerships for Caterpillar and John Deere were sold under the same roof, it was natural for the crawler buyer to purchase the JD Killefer items to pair up.
Bursitis: I saw your query about the wheels in the FS section; I do not like them being loose or "floppy", but per everything I have read, that is normal even when brand new. I have yet to take one apart to see how they are assembled. I should make a point to try and get a parts book/list for one of these chisels or tool carriers.
I just bought another one that was converted to hydraulic. I am tempted to replace the spoked wheels with new hubs and rubber tires, but then again, it works fine as is. JM
2 years 3 months ago #238114
by bursitis
Thanks Juiceman.....i messed with them some this morning and found a big nut that when tightened it helps correct the slop. i also noticed an inner castle nut with a big cotter key in it. i will look into it further
2 years 3 months ago #238124
by GrantJ
The big outer nut that your photo shows is what I have not been able to break loose. It is a John Deere Killefer model 2-02. I had a 3 foot pipe wrench + 6 foot cheater bar plus heat and only managed to break a small chunk of metal off of the nut. If you locate a parts diagram or list, I would really like a copy. My even earlier Killefer (before John Deere) model 265 120 is in need of some parts also, so any information will be appreciated. Thanks, Grant.
Fat Dan
2 years 3 months ago - 2 years 3 months ago #238127
by bursitis
grant i suspect that there is a roller bearing set up instead of a taper bearing. not sure though. in my search i found some conversions to taper bearings made by the Amish or also new straight roller bearings made by same. the outer is just a big cast iron cap i think used like a grease cup to force grease. look right next to the hub you will see a very thin hex with external threads. tighten this and the hub snugs up. maybe take out the grease zerk and fill the cap with atf to loosen the internal threads caked with old grease???
bursitis.
Fat Dan
2 years 3 months ago #238131
by GrantJ
The grease zerk was missing so I filled it up with as much PB Blaster as would go into it and let it soak for several days then got out the blow torch and big wrenches. The wheel was stuck in the beginning but it broke free after a while but the big nut would not budge. I am pretty sure that the bearing that was rusted solid, wont last too long. Do you have a link to the Amish group that sells conversion bearings? I am amazed at how little information I have been able to find about Killefers. Any help is appreciated. Thanks, Grant.
Fat Dan
2 years 3 months ago #238134
by GrantJ
I will see if I can post a couple of photos.
Well as usual my photo program is too smart for me. I think that these attachments will show. This looks like a smaller version of what Juiceman sold. Somone converted it to hydraulic but I an converting it back since I dont have hydraulics on my Cat 22. Do the photos give any indication of what it was originally intended for? Grant.
Fat Dan
Time to create page: 0.182 seconds
