933G oil filter
933G oil filter
2 years 4 months ago #237902
by Broo1874
Just bought last year so this is my first oil change. My manual says the oil filter is T20646. I can’t find that part number online. The local dealer wants a serial number or they won’t help me. I have tried reading it off the block but can’t make it out. Can anyone help me with a part number and place to order one? Thank you in advance for your help.
Fat Dan
Thank you received: 103
2 years 4 months ago - 2 years 4 months ago #237903
by Fat Dan
A second S/N should be found on rear of transmission case, top left,
ACMOC Membership
Last edit: 2 years 4 months ago by
Fat Dan. Reason: Clarity
Broo1874
2 years 4 months ago - 2 years 4 months ago #237904
933G model runs s/n 42A5918 to 42A9202
Original oil filter part # is 7M3800 = 1R0659 current Cat number or Wix 51161
2 years 4 months ago #237905
by Fat Dan
I've been looking and found the 933"C" 955C, 955E used a Cat 9F6700 p/n for replaceable filter
WIX
Product Specifications
Part Number: 51161
UPC Number: 765809511613
Style: Cartridge Lube Metal Canister Filter
Service: Lube/Hydraulic
Type: Full Flow
Media: Enhanced Cellulose
Height: 9.277 (236)*
Outer Diameter: 3.968 (101)*
Inside Diameter: 1.635 (42)*
Beta Ratio: 2/20=17/33
Max Flow Rate: 18 GPM
Nominal Micron Rating: 32
( )* denotes metric
Gasket Diameters
Number O.D. I.D. Thk.
15449 Packed 4.815 (122)* 4.585 (116)* 0.125 (3)*
15286 Packed 4.79 (122)* 4.63 (118)* 0.125 (3)*
15108 8 4.458 (113)* 4.25 (108)* 0.125 (3)*
Principle Application: Autocar, Bay City Shovel, Caterpillar, Gardner-Denver, Koehring, Komatsu
ACMOC Membership
2 years 4 months ago #237906
by Fat Dan
Ya beat me to it OM 😁👍
Quick draw McGraw..😁
ACMOC Membership
Thank you received: 251
2 years 4 months ago #237908
by juiceman
Fat Dan: You have to be fast on your feet, OM does not let the moss grow under his hat! Thanks for BOTH of you for assisting the original poster. JM
Fat Dan
933G oil filter
Time to create page: 0.153 seconds
