Cat 955 12A series
Cat 955 12A series
2 years 4 months ago #237559
by BillySanders
Does anyone know if a 955, 12A series with a pony start engine can be fitted with a direct start starter. Is there room for a starter, is there already a hole in the side for one??
Any info would be greatly appreciated...
Fat Dan
2 years 4 months ago - 2 years 4 months ago #237563
Yes and yes. The 12A's have provision for direct electric start including the larger diameter pre-combustion chamber heads that allow use of glow plugs.
Fat Dan
Thank you received: 103
2 years 4 months ago #237564
by Fat Dan
My herd of Cat 955 12A's
I like using the pony motors mainly because I live in Alaska and cold starts are hard on everything.
Oil pressure comes up slowly in the D315 and D318. I believe the filter hosing needs to refill on each startup, Keep a close eye on the oil pressure.
NEVER EVER use either with glowplugs !
Good luck
ACMOC Membership
2 years 4 months ago #237565
by Fat Dan
FYI as per Ol Magnet ... thanks OM,
@ 12A5793 the undercarriage went from a D4 to a D6
ACMOC Membership
Cat 955 12A series
Time to create page: 0.143 seconds
