Finding master pin on d4 6u and 7u
Thank you received: 11
2 years 5 months ago #237338
by Reisingerweld
Looking to split 2 sets of tracks and on any of the 4 assemblies I can't for the life of me find a dimple or hole or any identifying mark to tell me which pin is the master. Any idea on how to figure this out?
D4 6U9483SP
Hyster D4N winch
Thank you received: 63
2 years 5 months ago #237343
by PhilC
The only way I can think of is to look at the pin between the link and see if you can see a split bush. You may be able to use a thin rule to see if it reaches in as far as the track pin. If it does it's the master.
I have the same problem with my 305CR excavator tracks. I have to remove a link but I can't identify the master pin so I put the rubber tracks back on for now.
2 years 5 months ago #237349
As PhilC says, as a last resort use a feeler gauge (hack saw blade etc) to fish for the short bushing.
Thank you received: 387
2 years 5 months ago #237358
just a suggestion once you find it mark the ends with a M so you can find the bloody thing easily next time. a large letter stamp should do or a engraver
2 years 5 months ago #237360
by PhilC
Forgot to mention check both sides of the chain as the link may be hard up against one side but have clearance on the other side.
Also as tk88 said mark it for future reference but use a grinder or drill a witness hole in the end of the pin. Especially if you have track guards on as they will obliterate engraver or letter stamp marks.
Thank you received: 7
2 years 5 months ago #237373
by caterpillar13
i painted the master link real heavy and then did it years later, and i twisted a heavy wire around the spacer post in the rail link
