Diesel Forty vs RD6
Diesel Forty vs RD6
Thank you received: 25
2 years 5 months ago - 2 years 5 months ago #236995
by ironman3406
Well John that does bring up an interesting question. I went digging though some of my Cat books and found this... Maybe there is more truth to the Roosevelt argument than I give credit.
Nathan Duncan
Thank you received: 11
2 years 5 months ago #236997
by Jim Allen
It just doesn't sound right, though, Ironman. I can't imagine a company publicly kissing up that much. Having studied a LOT of engine and vehicle manufactorers over the past 40 years, the most likely affliction is "nomenclature schizophrenia." All companies seem to go thru a period when a suit in marketing has a little too much to drink one night and comes up with a "great idea" that has people scratching their heads 80 years down the road.
Look at the product nomenclature evolution. First they had the Spelled Out designations, from day 1 into 1935. Then they divided the line into the gas powered "R" and diesel powered "RD," the "D" being for diesel of course. It's a common sense way to do it. Starting in 1937, realizing 80 percent of the product line was diesel, they rationalized rationalized to "D" because the vast majority of their product line was moving to diesel. Of course some of the product lines overlapped but eventually gas engines were gone and so were the pesky R-series.
Art Rosen is one of my top 10 "Gearhead Heroes," by the way, so if I was going to "wish" and vote my heart about "RD", it would be that. But I live in realville.
Jim Allen
Keeping the Good 'Ol Days of Four Wheeling Alive
Thank you received: 409
2 years 5 months ago #237007
Cat still make gas engines, although they don't fit them to anything but generating sets as far as I know. The "gas" these days is natural gas, but I'm sure an enterprising fellow could run them on gasoline with sufficient tweaks and a carb or injection since they basically have all the parts needed for spark ignition. I don't know if they've made gas engines continuously but I'd guess there was a gap between the gas-powered tractors and the industrial gas engines. Perhaps a topic for the magazine from someone knowledgeable?
Thank you received: 285
2 years 5 months ago #237013
by gauntjoh
Jim, not sure where your article on the Diesel Forty is destined for, but perhaps if it could be submitted in due course for inclusion in our club magazine?
Thank you received: 37
2 years 5 months ago - 2 years 5 months ago #237023
by Jim Allen
The Diesel 40 with the 5 3/4” bore that was tested at Nebraska was a 5E serial number tractor.
Which I mentioned above. Both the tests list it as a "Diesel Forty" but was it an RD-6 in reality? Was there a production "gray area" where the Diesel Forty and RD-6 models were blurred? Or was it a labeling mistake made by Nebraska. ?If it was the latter, you'd have thought Cat would've called 'em on it. The theory that floats in my brain is that the RD series wasn't completely rationalized as a model line at the point the tractors were submitted for tests. But yeah, 5E is one of the designations used for the early days of the RD-6. I think this is an important fact to line out and the resources I have available don't do it. Hence, my appealing to the more knowledgeable and better referenced here?
Also, I call your attention again to the differences between test 242 and 243. One is run at 850 rpm and the other at 1000. Since there are no tests of an "actual" RD-6, I can only go by the official specs, which list 850 rpm. So was the 1000 rpm test an experiment or?????
Jim Allen
Last edit: 2 years 5 months ago by
Jim Allen.
Thank you received: 387
2 years 5 months ago #237117
some might not know the delo range of lube oils were originally developed with caterpillar by standard oil company. and stands for Diesel Engine Lubricating Oil.
chevron the current owners of the delo name have recently grouped all there diesel and heavy equipment oils under that banner.
Thank you received: 191
2 years 5 months ago #237131
by D4Jim
A very interesting article about the development of diesel oils and the need for a one cylinder test engine!!
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
Jim Allen
Diesel Forty vs RD6
Time to create page: 0.226 seconds
