D2 Diesel fuel in crankcase
2 years 5 months ago #236801
by PeteGluhaich
Hi All,
My direct start orchard D2 5U had fuel in the crankcase. It had been running fine until after it's winter rest. Did some discing and started getting hot, and finally shut it down. Next day checked the dip stick and sure enough super clean and diesel in the crankcase. Rebuilt the transfer pump, but checked it today and ran it for a short time. and again diesel in the crankcase. The injector pump seems to be fine. Runs perfect when running and opened side cover on injector pump, and not leaking. What is the routing of fuel from the transfer to the injector pump? Or is the there a way for fuel from the injector pump or elsewhere to get into the crankcase? Thank you in advance! Pete
Fat Dan
Thank you received: 191
2 years 5 months ago #236802
by D4Jim
Probably the seal that goes between the injection pump and the fuel tower. Very common for it to leak fuel into the crankcase. See upper right photo #2. Injection pump has to come off to replace it.
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
2 years 5 months ago #236803
by PeteGluhaich
Thank you! Thought that might it, but needed confirmation from someone that knows. Thank you again!
Fat Dan
Thank you received: 103
2 years 5 months ago #236805
by Fat Dan
Good luck on your project and keep us informed on how things went.
ACMOC Membership
Thank you received: 142
Time to create page: 0.270 seconds
