Push or pull Fan shroud and fans
Thank you received: 7
2 years 5 months ago #236727
by Basdas
Good morning I had such a good response to my first question I thought I would throw in my second question on a new topic. I have a 1958 D4 7U42585 I have two fingers the stock four-bladed fan with fan shroud. The previous owner also had the pusher fan which is six blades but it takes a different fan shroud from my understanding.1. Which fan would be better to use in Southern California a push or a poll fan?2. and where would I look for a push your fan shroud since they took different fans rounds depending on if you had a pull or push fan? Also the wire mesh protector that goes over the fan shroud.Thanks again for any input advice or where to acquire these.
2 years 5 months ago #236728
by Basdas
I apologize not too good with the computer hopefully you found my questions buried between the pictures that are duplicated.
Fat Dan
Thank you received: 53
2 years 5 months ago #236730
by FroghairFarm
Basdas - I can't help you with the specifics of the question, but I would recommend joining up so that you can access the library where you can get to the parts catalogs for these machines. It's well worth the small investment! I have found it very, very helpful.
D4 D 78A 6678
D4 6U 1139
D2 5U 1164
JD 350B
JD 420C
Fat Dan
2 years 5 months ago #236731
by Basdas
Thanks for the advice my plan is to join right now I’m spending most of my money supporting Caterpillar and the parts they supply so Get my machine running. But yes my plan is to join thanks for the advice I do appreciate it very much.
Fat Dan
Thank you received: 620
Thank you received: 15
2 years 5 months ago #236734
by Glum
I would make sure the rest of the machine is fully functional before worrying too much about the fan type.
It's been my experience that if you have a suction fan and are brush clearing, you need to keep a good eye on the temp guage and have a thin stick or wire to scratch the leaves and twigs out between the #44 hydraulic control and mesh screen every few hours.
Fat Dan
2 years 5 months ago #236736
by Basdas
There’s a screen? Where can I get one? I don’t have that. Where would I get fan shroud for push fan?
Found these part numbers for wire mesh guard
8f7808 and 8f7807
Fan shroud 4f9114 and 4f9113
Looking for shield part #
Fat Dan
Thank you received: 409
2 years 5 months ago #236740
The shroud sits behind the fan and in front of the engine. The screen sits in between the radiator and the #44 hydraulic control in front. That heavy #44 guard that's leaning forward needs to be bolted back to the radiator at the top to protect it. You can search machinerytrader.com for those part numbers. Also post a want ad on the For Sale here - someone may have a spare to sell you
Thank you received: 387
2 years 5 months ago #236783
most dozers had push fans to keep the rad clear. any farm crawlers that worked grain crops tended to have push fans for the same reason.
most modern large farm tractors have reversible fans some are automatic being electrically driven so they simply use a timed relay to stop and reverse the fan. others are mechanical.
its important to regular clear the rad when working in dry, dusty, muddy and leafy conditions many farmers have lost machines due to fires from dirt and vegetation build up around radiators and transmissions.
dont use wire or sticks to clear the rad to big a risk of puncturing the core. use a hose or compressed air instead. old refillable water fire extinguishers are good for this you can charge them with water and air or just air. the uncle worked for a bailing contractor they always had a couple filed with water when they were working in dry conditions.
Fat Dan
Time to create page: 0.199 seconds
