D -311 Engine side covers
Thank you received: 5
2 years 5 months ago #236665
by dead axle
Didn't know if any of you have encountered this before. I'm trying to find the part number for the gasket on the two, engine crankcase inspection covers, on the injection pump side of the block. The parts book only shows the four inspection covers on the opposite side of the engine. I have tried the parts book on my 9T533 212 grader and also my 5U11427 D-2. Neither manual shows a view of that side of the block. Next stop is the Cat parts counter if no one here can help.....ThanksĀ
Thank you received: 387
2 years 5 months ago #236667
are the originals paper or cork. as sheet cork is still available from most industrial suppliers, engine rebuilders and auto parts joints.
you could also use nuetral cure rtv silicone, or loctite master gasket 515.
2 years 5 months ago #236668
there is a seperate parts book for the engine it might be listed there. or are they the same size as the others.
2 years 5 months ago #236669
by dead axle
Yes, the originals are cork, and I could make them, but for the cost of most of those factory gaskets, why bother. I'm sure Cat can come up with the number, I just thought someone might have additional parts book or micro fiche.
2 years 5 months ago #236670
4B3201...look in the window view of the half engine end view to the right of the main engine side view in the parts book.
Fat Dan
Time to create page: 0.147 seconds
