931B won't move
931B won't move
2 years 5 months ago #236651
by David Hess
My 931B suddenly barely moves. Everything was fine until I drove 4 miles down an icy mountain road, 25° temp, top speed (3rd gear). Drove a hill with left track in snow for traction. 1, 2 & R, moves a bit, nothing in 3d. All fluids & filters full & clean
Thank you received: 20
2 years 5 months ago - 2 years 5 months ago #236660
by David Hess
Thanks. I let it run for an hour! Will start to move a bit - 20 feet, then just slows and stops. Do you think I should replace the strainer?
Last edit: 2 years 5 months ago by
David Hess. Reason: Added to.
2 years 5 months ago #236661
Not necessary to replace the strainer unless it is damaged. Just clean and replace.
If that doesn't do it you will need to get pressure tests on the transmission. Looking for leaks or pump problems.
Thank you received: 387
2 years 5 months ago #236666
check the the simple things first. sometimes it is something so simple you wouldn't think of it.
a nearby mine had a haul truck that wouldn't start they tested everything and the service tech believed it was a bad engine control module 14 grand later and it still wouldnt start so they refitted the original. the apprentice decided to check the fluid levels it was low on oil topped it off and hey presto it started with the original module.
the watch dog was interrupting the start protecting the engine from lack of oil.
and no the dealer wouldn't accept a return on the part. so they now have 14 grand worth of paper weight sitting on the shelf.
Deebo
Thank you received: 104
2 years 5 months ago - 2 years 5 months ago #236673
by Deebo
Further to the original poster’s request, we’ve no manuals for the 931B in the Tech Library. If anyone has any scanned copies could they let me know at This email address is being protected from spambots. You need JavaScript enabled to view it.. Thanks.
Deebo.
931B won't move
Time to create page: 0.161 seconds
