D4 with rear ripper
2 years 6 months ago #236529 by Deas Plant.
Replied by Deas Plant. on topic D4 with rear ripper
Hi, Old Magnet.
Yep, the Cat 941 and 951 track loaders had the same arrangement, complete with shims to cater for wear so that you could keep the load concentrated at the drawbar pull point if wear occurred at the drawbar pivot pin under the transmission.
2 years 6 months ago - 2 years 6 months ago #236537 by Old Magnet
Replied by Old Magnet on topic D4 with rear ripper
Yes, the 941 and 951 rippers are similar but only the 58Dxxxx series has the "U" model and 12Axxxx mounting group.
The draw bar pin and bracketĀ  was not used with the ripper attachments. Front connection was directly bolted to the case bottom where the drawbar pin bracket would be. Shims were used to give some leeway to the fit.
Last edit: 2 years 6 months ago by Old Magnet.
Time to create page: 0.133 seconds
