74A clutch brake adjustment
Thank you received: 28
2 years 7 months ago #235368
by 74A6C
While working on the interlock, I noticed the clutch brake was gone again. I've put one on it before, but I don't reckon I had the adjustment right as it didn't last but about 150 hours or so. Looking in my service manual it's only got the adjustment dimension for the spring type linkage shown in the parts manual for tractors up to serial 1388. Mine has the solid linkage shown from 1389 up. The service manual is a genuine Cat Form RE00034 for 74A1-up and 76A1-up. Am I missing something in the manual? Anyone have any other info? Any help would be appreciated.
Thank you received: 67
2 years 7 months ago #235398
by kittyman1
looking thru my service manual, i don't see much detail on the clutch brake....but i did find a basic nugget that might help..
1) put the flywheel clutch hand lever in the fully forward position
2) loosen locknut
3) turn rod until the shoe assembly makes contact with the brake drum
4) release the flywheel clutch hand lever
5) turn rod 2 turns clockwise
6) tighten locknut
-so basically brake shoe is loose enough to have clearance and not drag (unnecessary wear) and the brake is not applied until the last bit of travel when the lever is pressed fully forward
-the rod is vertical, left side of clutch assembly, next to the outside panel and in front of the magnetic/screen filter housing, you will see a yoke on the bottom side of the rod..and the locknut contacts the yoke to lock rod in position
74A6C
2 years 7 months ago #235400
by 74A6C
Thanks, I appreciate the info. I'll try it this way this time. Going by the dimension given for the other style had it running entirely too tight.
2 years 7 months ago #235408
by kittyman1
yes it's pretty basic, as long as the rest of the pins and linkages are reasonable, brake shoe not coated in oil or grease....should work fine
- i notice with mine it takes a lot more brake effort initially until the trans oil warms a bit then it's good
74A6C
2 years 7 months ago #235417
by 74A6C
I replaced a couple of pins in the linkage last time, everything seems fairly well good from what I can tell. Got a new drum to go on also. The one one it is pretty worn. I'll agree about the trans oil being warm. Wonder if a fresh oil change in the trans and flywheel housing would remedy part of that, expensive as it will be with current oil shelf prices? Plan on changing transmission oil anyhow since I've replaced the interlock shaft.
2 years 7 months ago #235430
Are you using a genuine Cat brake pad? I seem to recall someone stating the aftermarket units are not the same, too soft and don't last.
74A6C
2 years 7 months ago #235433
by 74A6C
The one I've got to put on this time is an aftermarket, but the first one I put on was far enough back I don't remember. That makes since though, maybe Cat uses better brake band material.
Thank you received: 620
2 years 7 months ago #235435
by Rome K/G
Send your old brake bands and friction brakes to Arts Parts, Norwalk Ohio He does excellent work and applies the correct friction material. Does allot of Cat bands and all makes of crane bands too. 614-565-0506
2 years 7 months ago #235451
by kittyman1
i never noticed any clutch braking/shifting difference when i changed my trans oil, nothing noticeable at all
-but changing oil is never a bad thing in my books (any brand) (any price range)
Time to create page: 0.186 seconds
