D6B pinion
D6B pinion
2 years 8 months ago #234972
by Stuss
Hi I’ve removed the pony motor from my D6B , and now having trouble finding a pinion to suit the teeth on flywheel as there not straight
Thank you received: 142
Thank you received: 63
2 years 8 months ago #234975
by PhilC
Old Magnet is the Guru on these but I assume you need something
like this.
2 years 8 months ago #234980
Do you have a starter now? and is it a Delco 40MT or 42MT?
Either one will also require the 1M0023 eccentric adapter due to the buzz bomb pony motors having a larger hole in the flywheel housing than the normal direct start drive end housing.
The starter drive you need is this one, along with the correct drive end housing.
Stuss
2 years 8 months ago #234995
by Busso20
I think a fella named Davis does the complete starter unit with the helical gear in Toowoomba Qld only as complete kit.
2 years 8 months ago #235001
by Stuss
Hi Busso 20 yes John Davis sells complete setups and won’t sell individual parts, about $1800 for a setup. It’s good value if you want to go that way.
2 years 8 months ago #235005
by Busso20
HI Stuss, yes I guess so, a little hard to justify if not used regular, I managed to sort both my pony's out and was lucky to secure another for a rebuild to be exchanged when needed after I build it.
D6B pinion
Time to create page: 0.171 seconds
