12E 9K9063 motor grader questions
2 years 8 months ago #234799
by Bernard
New member here.
I'm looking to possibly buy a grader with s/n 9K9063 and labeled 12E. I understand that the 9K series was built from 1938 to 1945, but the 12E dates from 1959 to 1965. Anyone know how to explain the discrepancy? It has an inline 6 with pony motor.
How hard is it to overhaul the foundation brakes?
The tires are dry rotted pretty bad but hold air. Would tire chains keep them from falling apart?
Thanks!
Thank you received: 142
2 years 8 months ago #234800
by bursitis
it isn't a 12E someone just put the wrong decal on it sometime ago when it was painted. the brakes aren't difficult to work on but getting the wheel center off can be a chore.
Thank you received: 191
2 years 8 months ago #234825
by D4Jim
Tire chains will only exacerbate the dry rot problem. Looks like the rear tandem tire is a severe misfit or the photo is distorted. Se# is 1945 and probably has the D4600 engine.
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
2 years 8 months ago #234827
by Bernard
Here's a closer photo of the LR tires. I think they're the regular size, 13.00-24. Also a shot of the RR, quite rotted.
Is a pdf shop manual available?
Thanks for the info!
2 years 8 months ago #234835
by D4Jim
A 9K Service Manual and a 9K parts manual are available in the technical section. Didn't see an operators manual.
D47U 1950 #10164
