D4 Oil cooler delete
Thank you received: 20
2 years 9 months ago #234183
by 8C 361
On my recent auction purchase D4 7U 22xxx I drained oil and water out of steering clutch compartment, flushed with gas, changed oil and transmission fluid and got everything working good. The first time I put it to work the oil cooler started out to leak.
I have bypassed these before. I understand if this plug is removed, a spring and plunger can be removed and the inlet and outlet ports can be plugged. Matching the threads in the ports is always a problem, they are close to 3/4" not but are not tapered. I am afraid if tapered pipe plugs are used it could crack the casting.
I recall Old Magnet mentioned a source for proper plugs for these ports. Could you tell me where I could get them?
Thank you,
Tom Armstrong
Thank you received: 620
2 years 9 months ago - 2 years 9 months ago #234186
by Rome K/G
The plug is to drain the filter housing, the cap with two bolts contains the spring and plunger. The plugs and gaskets for the housing are 2-6B2731 Plug and 2-8B3410 Gasket, from Cat.
Last edit: 2 years 9 months ago by
Rome K/G.
8C 361
2 years 9 months ago #234190
I use -10 size 0-ring face seal plugs (hydraulic fittings) which are a 1" - 14 tpi straight thread and bit of sealer.
They only run a couple of bucks each.
8C 361
Time to create page: 0.127 seconds
