Cat D8H 46A26253 Final drive service tool
2 years 9 months ago #233845
by Paul Sargent
Hi,
I am working on a Cat D8H serial number 46A25253 right hand final drive. We need rent, buy, or barrow the following service tools 8B7548 bar, 2 each 8B7752 rods (replaced 5F7369), 8H684 ratchet, and 8B7560 steel plate (can probably fab this one?). If anyone has a source or ideas, please share my email. This email address is being protected from spambots. You need JavaScript enabled to view it. or cell is 304-389-9729.
Merry Christmas!!!!
Thank you,
Eric
Thank you received: 341
2 years 9 months ago #233866
by edb
Hi Eric,
the 8B7752 Legs/Studs are shown in the scan for General Pullers and are from memory OTC or similar brand.
The 8B7548 Bridge is shown on the above scan but not identified and also shown in the D8H FD Tools scan #5, figures #12 and #14.
The ratchet we had at the Dealer but never saw it used for the puller centre stud nut and thrust bearing--we used open end /ring wrenches.
Some Dealers will hire tools and some do not here in Australia.
Hope this helps others identify what you are after.
2 years 9 months ago #233867
by edb
another couple of scans of Cat General Purpose Pullers FYI.
Thank you received: 57
2 years 9 months ago #233869
by Wombat
When you get to adjusting outer bearing preload, don't bother making the adapter as pictured for D8H and D9G, just weld a 15/16" nut to the center of outer housing.
Regards, Wombat
Time to create page: 0.149 seconds
