CAT NO.12 7T pony motor starter ID
Thank you received: 7
2 years 9 months ago #233778
by Oakfan707
The spring and gear on my starter are pretty much shot but the ID plate on my starter is wore really bad. I know its a delco remmy. Searching on google the only style it resembles is an Alice Chambers. Was wondering if anyone had any insight or knowledge on this. I am looking for a rebuild/repair kit or at the minimum the gear and return spring
CAT Twenty Two crawler 2F4426W
CAT No12 Motor Grader 7T345
Fat Dan
Thank you received: 153
2 years 9 months ago #233779
by rax200
Hi Oakfan707,
The Bendix is a Cat part No 9B8901 or a delco 1868804, 1915898 there are plenty on Ebay
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
2 years 9 months ago #233780
by Oakfan707
Thank you I'll search the numbers. I really appreciate it
Fat Dan
2 years 9 months ago #233792
by Oakfan707
Thank you so much. You're knowledge is invaluable. I was able to buy the starter shaft parts i needed right now but found some other parts I'd like to replace while its apart. This will help tremendously in getting the right kit/parts. Thank you again
Fat Dan
2 years 9 months ago - 2 years 9 months ago #233793
Be aware of aftermarket parts. Armatures don't have the the shaft pressed to the correct depth. Commutator end plates do not fit properly, brushes can be wrong fit. Only the old NOS filko push button switches fit and work correctly. Field coils are ok. Terminals are ok. Bushings are ok. Be sure to set up end thrust correctly. Look for a commutator end plate that has the bushing upgrade. Early versions ran on the pot metal.
2 years 9 months ago #233797
by Oakfan707
Thank-you so much for the info. I bought an aftermarket part and had no idea about that. I would've been bent hahaha.
Fat Dan
Thank you received: 42
2 years 9 months ago #233798
by restore49
Possible Bendix upgrade SDR5022 - think I may have used this on a D6 - will cushion the shock better when using 12 volts
2 years 9 months ago #233799
Better to use the early type bendix although most are now imports. Sometimes possible to find a USA built unit but it's the same one used on early flat head fords so most have already been scooped up.
2 years 9 months ago #233801
by Oakfan707
Thats awesome thank you. My Grandfather sells early ford parts so that is definitely useful
Fat Dan
Time to create page: 0.186 seconds
