Adding electric start to a D315
2 years 9 months ago #233759
by Iron Beaver
Hello everyone!
My D315 engine has a bolt-on plate covering a hole for an electric starter. I want to add electric start to save some wear and tear on the pony motor.
What parts are needed for this and where do I get them?
Fat Dan
Thank you received: 103
2 years 9 months ago - 2 years 9 months ago #233762
by Fat Dan
I asked that question myself. The answer starts with a change in generators to 12v or 24v and precups with glow plugs 12v or 24v then there is the matter of the starter ($900+ ) and that's just for starters.. Pun
to have both even becomes more cumbersome. With the duel starting systems you may need duel charging systems Systems that had D315 diesel ele start were generally stand alone generators and some marine applications.
I decided to keep the pony and the D315 tuned to help. But it is not really that bad if one follows the manual; pony starting is so much easier on the diesel because it prelubes all the internal parts in the diesel, brings up the temperature inside the intake of the diesel (and if done right) the combustion of the spinning diesel heats the head quicker. Then when you pop the fuel the D315 comes to life.
Oops forgot ..Heats up cooling system too ... DUH
ACMOC Membership
Last edit: 2 years 9 months ago by
Fat Dan. Reason: Clarity
Thank you received: 142
Thank you received: 42
2 years 9 months ago #233764
by restore49
If that is a D4 Old Magnet has all the instructions in Tech Library?? My D2 - junkyard Mt42 ($20) easy rebuild - new nose and helical gear.
2 years 9 months ago #233765
by Fat Dan
No that's a first for me... Thanks
I'm a cheap Bass turd and the price tag seemed too high for me. I'm mostly here for the fun of the old rigs anyway so I decided to embrace the pony experience.
ACMOC Membership
Time to create page: 0.153 seconds
