Anyone know the model # of this blade?
Thank you received: 53
2 years 9 months ago #233439
by FroghairFarm
I am looking for the model # of the blade on my D4, specifically, I want to get new end cutting edges and am looking for a part number. Any recommendations for where to buy the parts are welcome.
D4 D 78A 6678
D4 6U 1139
D2 5U 1164
JD 350B
JD 420C
Thank you received: 620
2 years 9 months ago - 2 years 9 months ago #233441
by Rome K/G
That would be a 4S blade, 60" Gauge, serial number from 67E4791-UP. Cutting edge is three piece for the center, 1-4T2983 $68.60 Stock Order Cat, 2-4T2972 $98.69 each Stock Order Cat, RH end bit # 4T3051 $64.63 Cat, LT end bit # 4T3052 $64.63 Cat, 23 Bolts # 3F5108 $1.74 Cat, 23 Nuts # 4K0367 $0.88 Cat. Torque bolts[one end to the other of edge] to 200 ft lbs, strike head with hammer and retighten, make sure surfaces are clean.
Last edit: 2 years 9 months ago by
Rome K/G.
2 years 9 months ago - 2 years 9 months ago #233444
by Rome K/G
Actually your blade is the 67E1-4790 range but the higher serial number blades just went to a three piece cutting edge system and did away with the guard on top of the blade. You also have the two 5J2424 Plate Assem. or angle support brackets at the top corners of the hardnose, these were on the early 78A1-UP tractors.
Rome K/G.
2 years 9 months ago - 2 years 9 months ago #233453
by FroghairFarm
@Rome K/G - Thank you! And a big thanks for mentioning the support brackets on the hardnose, I assumed they were a fabricobbled add-on. What were those brackets for? ROPS?
Serial # on my tractor is 78A6618
D4 D 78A 6678
D4 6U 1139
D2 5U 1164
JD 350B
JD 420C
FroghairFarm. Reason: clarification
2 years 9 months ago #233454
The pins and brackets are factory, used to support the lift cylinders when the blade is removed.
2 years 9 months ago #233455
by Rome K/G
Your welcome.
Thank you received: 13
2 years 9 months ago #233460
by Rodten
What is the serial number of your blade? I have 8 parts books for the 4S and 4A bulldozer if you are interested in one, but I would want to make sure I match book with your machine.
2 years 9 months ago #233463
by FroghairFarm
take your pick!W
Wow! Thank you for your generosity, I'll take you up on that! It may be a few days before I'm back out at the farm, but when I am I'll look for the serial # and get back to you.
D4 D 78A 6678
D4 6U 1139
D2 5U 1164
JD 350B
JD 420C
