D9G update
D9G update
Thank you received: 21
2 years 9 months ago - 2 years 9 months ago #233290
by Misterskill
Hey Fellas, Well the old girl hasn't caused me any issues for a while which has been delightful. Anyway, a few pictures of the mischief we've been up to.
Pushing the top off for the excavator
And again, getting the hang of this slot thing
Bloke building a new dugout and needed the floor level taken down a meter or so. Really long pushes and not a straight wall to begin with but we got there in the end.
And hitching a ride to the next spot
Thank you received: 279
2 years 9 months ago #233292
by Deas Plant.
Hi, Misterskill.
Good stuff and thanks for sharing. I have long thought that the D9G was a better dozer than the D9H which followed it. The heavier blade on the H series made them a little front heavy and also caused frame cracking issues above the equaliser bar until Cat beefed that area up a bit. The Hs were also more inclined to bust planetary final drives due, I suspect, to the extra 25 donkeys under the lid.
A 'kwestyun' if I may: That ripper appears to me to have originally been a single shank ripper with the pin puller and the rear push block to which some enterprising soul has added the two extra pockets. The afore-mentioned pin puller and rear push block and the fact that the two outer pockets appear to be in line with the outer edges of the tracks instead of with the centerline of the tracks are what make me suspect that this is the case. Are you able to verify this? Checking out the welds might give a clue.
2 years 9 months ago #233456
by Misterskill
I reckon you might be right. Serial of the Ripper is 50G.
The theory with the rippers further out was too help getting the walls straight.
edb,
Fat Dan
2 years 9 months ago #233459
by Deas Plant.
Hi, Misterskill.
"Getting the walls straight." Yep, that would make sense, even though there are other ways of doing it. Depending on the material, this 'trick' might well be quicker
Thanks for the reply and the extra photo.
Fat Dan
2 years 9 months ago #233507
by Deas Plant.
Hi, Misterskill.
I picked that this was your machine from the ripper beam even before I saw your name as the poster.
And another one:
Lookin' good.
Thank you received: 103
2 years 9 months ago #233509
by Fat Dan
🤔There's more than one way to skin with a Cat... er something like that.😁
ACMOC Membership
D9G update
