- Thank you received: 77
Yes it would. I’m sure it was at one time. I can see signs that it had a cab.
BP.
***It looks like Bruce likes them TOPLESS! Come on, your kids are getting too big to use the cabs as playhouses and bus stops, what became of it? I see the famous notches burned out of the nose for air conditioner compressor? No wonder you said space was becoming scarce...
Is the turbo on that one factory for altitude or more kitties? We will surely get to see shiny track pads if it snows there. Videos of you plowing the ski road? You cannot let the D6 have all of the glory!
Another nice score for BP. Love it! JM
Usually oil transfer is from engine to clutch compartment threw rear engine crankshaft seal if both oil levels are correct
Thats the way I usually figured it. Owner said he was driving fence posts with the blade and slipping the clutch quite a bit. I figured the oil in the clutch compartment got pretty hot, and if the clutch breather was plugged, it might start to push oil into the engine. I’ll check that breather first.
BP.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
