7u precleaner help
7u precleaner help
Thank you received: 183
2 years 9 months ago #233166
by d2gary
I'm trying to find a part number for the plastic precleaner cup. I have the 27570-up parts book but it doesn't list the precleaner cup.
I was going to put the old style precleaner with the jar but the tube is different size.
The air cleaner has a Donaldson tag on it.
Can someone provide a part number.
Thank you received: 620
2 years 9 months ago - 2 years 9 months ago #233167
by Rome K/G
8H2023 Body $15.81 from Cat or plenty on ebay [caterpillar 8h2023]
Last edit: 2 years 9 months ago by
Rome K/G.
Fat Dan
2 years 9 months ago #233174
by d2gary
Thank you sir. One coming from ebay free shipping. Costs me $20 to ship from Cat or drive an hour and a half each way
Fat Dan
2 years 9 months ago #233185
by d2gary
Discovered fuel in the injection pump oil sump when I went to change it. Must have just started because its just starting to weep but definitely leaking past the seals. So it looks like the pump is coming off before I can get it out of the shop. Its always something with these elderly Cats!
Thank you received: 104
2 years 9 months ago - 2 years 9 months ago #233205
by Deebo
Looks like you’re sorted for the air cleaner cup but if there’s anything else you need to cross reference, in the Tech Library there’s a copy of the 1944 Accessory and Supply catalog and there are loads of Donaldson (and other OE manufacturers) parts diagrams in there. It’s a great resource for bearings and carbs too.
Deebo.
rax200
Thank you received: 341
2 years 9 months ago #233225
I've got one of those pre-cleaner units in service on a D4. I had to stuff a stainless steel (pot scrubber type brillo pad) in the inlet to keep mice out during long periods of non op.
2 years 9 months ago #233229
by Rome K/G
I've seen that happen also, varmits! lol
Thank you received: 387
2 years 9 months ago #233288
gary go into any tractor dealer they have the replacement bowls. bare & co (bareco) make aftermarket ones in several sizes go into any stockist any they are a stocked item. just need the pipe outside dia to match up. a whole precleaner is not much more expensive than the bowl.
7u precleaner help
Time to create page: 0.195 seconds
