D6 5R engine weight?
Thank you received: 50
2 years 10 months ago #233033
by hfdzl
D486? 4 1/4 bore 6 cylinder. weight with flywheel. Rome KG?
Thanks, Herb
R2 5E3562 SP U.S.A. W.9151
R2 5E3563 SP U.S.A. W.9152
Thank you received: 620
Thank you received: 94
2 years 10 months ago #233039
by josh
D486 automotive engine is 2120 lbs, does not include starting engine, and has a smaller flywheel and bellhousing, I would guess about 2500 total.
2 years 10 months ago #233040
by hfdzl
Thanks everyone for your knowledge and sharing.
Thank you received: 63
2 years 10 months ago #233041
by PhilC
The D6 5R has a D4600 engine. Weight is around 3100lbs.
Regards
Phil
2 years 10 months ago #233049
by hfdzl
4600 has 4 1/4 bore, D318 has 4 1/2 bore?
2 years 10 months ago #233050
by PhilC
I can't say about the D318 but the D4600 is the 4.25 inch bore.The D4600 was used in the D6 4R/5R and the D318 was used in the D6 8U/9U series.
gauntjoh
2 years 10 months ago - 2 years 10 months ago #233052
by hfdzl
OK< THANKS< clears the smoke out of my head. Never could follow Cat engine number series. Why they were what they were.
hfdzl.
Time to create page: 0.153 seconds
