What series introduced differential steering?
Thank you received: 409
2 years 10 months ago - 2 years 10 months ago #232914
Hi folks, which series in each of the tractor sizes first came with differential steering? Are current models equipped with it too? Reason I ask is that mouldboard plowing would seem to be an ideal application for diff steering because it could make for a very smooth pass down the furrow. Has anyone had direct experience of this and what, if any, disadvantages are there?
__PRESENT__PRESENT
neil. Reason: spelling
Thank you received: 57
2 years 10 months ago - 2 years 10 months ago #232915
by Wombat
I don't know all of the first of each series, the following is a start, D6H, D7H, D8N, D9R.
I had a wheat farming friend near Narromine NSW, during a wet year in the Sixties used an Oliver to get their crop in, they had two 660 International wheel tractors that they had to leave in the shed and double shifted the Oliver. Early Oliver's were diff steering of sorts, they had a diff and steering was by applying brake to one side. He said it was good to follow a line as correction was achievable whilst maintaining drive on both tracks.
Wombat
Wombat. Reason: wrong letter
Fat Dan
2 years 10 months ago #232924
Thanks Wombat, I'm a little surprised that I haven't found a youtube of someone ploughing with one. I watch the Italian videos and they're as jerky as heck trying to stay on course and I figured a diff steer would be an ideal application (if one was to use a steel-tracked tractor)
Fat Dan
Thank you received: 341
2 years 10 months ago #232928
by edb
does not answer your question directly but the link below is a brief description of the system in use from 2011.
I would be guessing to say if or not the system has changed as it worked well and was smooth to operate in my experience around the Dealer shop and surrounds of the test area.
Fat Dan
2 years 10 months ago #232937
Thanks Eddie, I looked at that one and about three others figuring out which components are connected to others. One guy made a model where the incoming bevel drive drove the planetary carrier for the center planetary, and the three sun gears are all on the same shaft, with the steering motor driving the right side ring gear. I can't tell if this is the same design as Cat's but I imagine it can't be too far different. Other designs have only two planetaries and the steering motor drives the two ring gears in opposite directions - seems like a simpler system than the three planetary system. Did the engineers ever state how much power it takes to run the steering motor (would differ for different models of course)?
Thank you received: 19
2 years 10 months ago #232947
by 1951D2
The 65 challenger ag tractor had it from the beginning. But you guys probably new that.
