- Thank you received: 103
That sounds like a plan, humm interesting oil instead of grease, ATF has more detergents ... I have just the grease gun for that ...the 9K i used to have had the exact set up in the pic. it would steer fine without the hydraulic assist functioning. you can help by over inflating the front tires but it shouldn't be all that much trouble. a little forward movement makes a world of difference. if your kingpins are frozen jack up the front and steer back and forth while greasing with a gun full of oil instead of grease.
I really did think of that first . That's my idea everyone. I'm embarrassed to say it but that was my first thought.Deas Plant. post=233027 userid=933Hi, Fat Dan.
Another 'trick' that would likely allow you to tow the 9K home would be to make up a SHORT - about 3 feet - rigid tow bar which would pretty make the front wheels follow you. You would just need somebody on the 9K to keep the steering centered.
2¢ more that's at least a dime I.O.U. now LOLHi, Fat Dan.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
