5R D6 piston liners
5R D6 piston liners
Thank you received: 50
2 years 10 months ago #232805
by hfdzl
Will later 4.5 bore engine liners fit into an earlier D6. D486? If they are not a direct fit is there a a possibility for remachining?
Thanks, Herb
R2 5E3562 SP U.S.A. W.9151
R2 5E3563 SP U.S.A. W.9152
Thank you received: 63
2 years 10 months ago #232807
by PhilC
Part number for the 4.25" liner is 7B4348 and they are still available from Cat. Are you wanting to put 4.5 inch cylinders in a 4.25 inch engine?
2 years 10 months ago #232816
by hfdzl
Hi Phil, No not really. Just was having a hard time finding anything aftermarket. That actually gave me size.
Thanks for the part #, that will help. Herb
Thank you received: 19
2 years 10 months ago #232957
by sheddcanyon
I was able to source six after market 4.25" liners from Florin. However, I had to have a machine shop skim-cut the bottom o.d. because they fit too tight in the bore. So you might be better off paying Cat's price and be done with it. Buy once, cry once.
2 years 10 months ago #232960
by hfdzl
If I find the parts for any project, I usually buy them, even if I don't need them right now. I have a lathe , I can turn the OD if I have to.
THanks
5R D6 piston liners
Time to create page: 0.150 seconds
