D4 Troubles, ohhh boy!
Thank you received: 620
Thank you received: 183
Thank you received: 191
2 years 10 months ago - 2 years 10 months ago #232619
by D4Jim
Was that really Abbott and Costello???? Nice looking old 4030!
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
D4Jim.
Fat Dan
Thank you received: 251
2 years 10 months ago #232622
by juiceman
When in doubt, some whip the hammer out! I wonder if anyone would allow me to try freeing up their rack with my trusty "SledgoMatic".JM
2 years 10 months ago #232624
by Rome K/G
Yea! I just shook my head, wow!
Thank you received: 153
2 years 10 months ago #232629
by rax200
Hi All,
You can see how well he maintains his tractors and machinery, if it brakes down and the maintainence mallet dode not work, just park it up and pull it apart.
Poor old girl, please save her
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Thank you received: 13
2 years 10 months ago #232637
by greengiant
hmmm! it never occurred to me to take a hammer to my D4's rack!
other than that, what is the best way to free it up? mine was sitting for 5 years ("running when parked") and starts good on ether but will not run on diesel despite the meter showing good fuel pressure, new fuel, new air filter. fuel oozes out the bleed points and injectors(doesn't squirt). so I'm assuming it's the rack. a "bigger hammer" or???
2 years 10 months ago #232648
by Rome K/G
Uh no hammer! remove the side plate from the pump housing and you will see the rack towards the top. Spray some rust cutter on it and let it soak, also the pump plungers can stick, spray some on them too. Then take a screw driver and lightly pry it back and forth.
Fat Dan
Thank you received: 44
2 years 10 months ago #232649
by GrantJ
I once started a D4 that had sat for a decade or more and it RAN AWAY, or so I thought. It was not smoking but screaming and no throttle control. I finally stopped it by cutting off the air. It turned out to be a stuck rack. I took a brass rod and lots of liquid wrench and GENTLY tapped the rack until I got it to move. It took a long time and lots of tapping to get it completely free, but it ran fine afterward. My point is BE GENTLE and it might work out. I think the brass rod rather than a steel rod is important. Good Luck with it. Grant.
2 years 10 months ago #232653
by greengiant
Thanks Rome and Grant, I was hoping it might be something like that. I was afraid to take the side plate off for fear something would fall out or the rack would get out of timing, but now I will do that.
Time to create page: 0.193 seconds
