4A angle blade hinge
2 years 10 months ago #232358
by Richard~J~W
Can anyone advise why this blade hinge doesn't fit? there is no i.d. on the blade, but it is attached to a D4D
its 2J850 as per the parts book but the hole size is 1/8" undersize (measured on the pin, not the worn hole) and the height is about 3/8" too much.
Thank you received: 620
2 years 10 months ago - 2 years 10 months ago #232362
by Rome K/G
Looks like the one on the blade was bored out and a bigger pin was used. I believe the new bracket has been updated. The bracket on the blade will have to be removed and relocated.
Rome K/G.
Thank you received: 142
2 years 10 months ago #232364
by bursitis
pretty common in my woods to bore the hole bigger and install a new pin to fit. usually done to tighten up worn blades etc
Fat Dan
2 years 10 months ago #232365
2J850 is the correct number.....so either the joint has been reworked or the replacement part is from the land of "almost right".
Fat Dan
Thank you received: 387
2 years 10 months ago #232388
id say it has a bush mechanic fix written all over it. maybe the original broke or they made it take a larger pin instead of a proper repair.
Fat Dan
Thank you received: 28
2 years 10 months ago #232429
by 74A6C
I'd agree with trainzkid, looks to have been reworked. "Cut to fit and paint to match" type scenario. Maybe the ears were moved to accommodate the wear.
2 years 10 months ago #232438
Being that the 4A blade uses four of those hinges, are they all the same on this unit?
Fat Dan
2 years 10 months ago #232559
by Richard~J~W
thank-you for all the replies....looks like i am gonna be busy with a half-round file
O/M, they look the same part.....I hope so anyway as I ordered 4 pcs
Fat Dan
2 years 10 months ago #232568
I was referring to the ones on the blade now. Are they all the same? May be that is not a Cat blade.
Fat Dan
Time to create page: 0.165 seconds
