Bearing puller and clutch drum??
Thank you received: 11
2 years 11 months ago #232288
by Zzzopp
More questions as I continue on my D4 7U repairs...
-Any pictures of puller used to pull bevel shaft bearings from a D4 7U/955 12A? Looks to be a pretty long reach puller. Before I build a set of pulling jaws I’m curious to what the proper tool looks like.
-One of the drums on my replacement bevel shaft (955 12a) is cracked. Anyone have one? 8H1174.
thanks.
Thank you received: 341
2 years 11 months ago - 2 years 11 months ago #232301
by edb
Hi,
we used to oxy cut the roller cage to remove the rollers, carefully set the shaft on end and heat the bearing inner race with an oxy torch using a largish cutting tip to get heat into the race quick before it soaks into the shaft--if you have done it right the race will drop down by gravity.
Edit--added some tooling I have used in the past at the Dealer for pulling such items but it is time consuming to set up and use.
Last edit: 2 years 11 months ago by
edb.
Zzzopp
Thank you received: 620
2 years 10 months ago - 2 years 10 months ago #232313
by Rome K/G
To install bearings heat in oil to 275 degrees F. This is also recommended by Cat.
Rome K/G.
Zzzopp
2 years 10 months ago - 2 years 10 months ago #232324
by edb
scan below is from Caterpillar for the recommended fitting temperatures for bearings etc.
edb.
Zzzopp
Thank you received: 94
2 years 10 months ago #232338
by Zzzopp
edb, Thanks for the scan!
Josh, I was able to get bearing puller on the bearing away from gear, the bearing that is pressed to the back side of gear doesn’t have room for a traditional bearing splitter. I ended up having to make some jaws.
Thank you received: 39
2 years 10 months ago #232339
by gemdozer
Press or drive the bearing out of the cage using a punch in the two holes in back of the bearing cage and applying pressure first through one hole and then the other
2 years 10 months ago #232387
by Nospark015
Fine business on the D4 pushing and pulling wisdom. We have two Twenty Twos and a Fifteen with bevel gear shaft endplay. Is there a way to remove the bevel gear shaft bearing inner races without pulling the shaft out of the bevel gear? Are there any tricks to reduce likleyhood of breaking the clutch drum? Also, how does one know when the bevel gear pressed far enough onto the shaft? If one is faced with some likely steering clutch, final drive and transmission rehab and considering investing in a shop press shall we aim for a 20 ton, 40, 50 or more? We located an older Fanco (Nugier) 40 ton and are looking at a Harbor Freight press. We have a well used 12 1/2 ton H frame and a 30 and 50 ton OTC puller set. Any thoughts would be greatly appreciated!
Thank you received: 409
2 years 10 months ago #232391
I removed my D2's inner races by carefully slicing them with the gas axe. You can practice on some old scrap. It's not necessary to slice all the way through. You can also try just heating them rapidly
Time to create page: 0.171 seconds
