Need help identifying a tool bar bracket ???
Thank you received: 44
2 years 11 months ago #232070
by GrantJ
I am trying to post a photo of a tool bar bracket (I dont know the proper name), so that I can find and buy a different size. I need 2 brackets like what shows at the top of the photo. They need to be for an 1 1/4 inch shank.. I have not found anything on line, but not knowing the proper name makes it difficult. I hope the photo works. Any advice is welcome. Grant.
Thank you received: 43
2 years 11 months ago #232093
by GrantJ
Thank you ag-mike. I was not at all sure if I had the vocabulary correct or not. I looked thru the link you gave, but did not see exactly what I need. I am going to look at ebay now and see what is available. I have a clamp that I took off of a plow bar that turned out to be for a 1 inch bar and the ripper bar is 1 1/4 inch. At least I have a better idea of how to ask for the part if I am calling someone. Thanks again. Grant.
Thank you received: 118
2 years 11 months ago #232117
by GrantJ
Thanks Ray, I went to an old time tractor mechanic that is near me and he said that the brackets that I have are not available anymore. I ended up taking the ripper bars to a local machine shop that is going to use some type of mill to shave the portion of the bar down to 1 inch so I can use the brackets that I have. These bars are really heavy so I dont think loosing a little metal is going to be a problem. They are 1 1/4 by 6 by 32 inches. Maybe I can post another photo.
2 years 11 months ago #232118
by GrantJ
Oops, I guess that I double clicked when I should not have. Sorry folks, I am learning. Grant.
Thank you received: 191
2 years 11 months ago #232126
by D4Jim
That is quite a different clamp than I have seen on other pieces of old farm equipment. The only way may be to fabricate one from bar stock and it could be done. The slot in it would only fit the one size shank. One of my old IH cultivators has a clamp for a 1" shaft but it transitions into a round shank. Hope you have Good luck finding one but it looks pretty rare!
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
2 years 11 months ago #232128
by GrantJ
It came on a plow type shank for a John Deere Killefer. I have been told that they have not made Killefers in many years. I have decided to have the ripper bars/shanks milled down to 1 inch and use the clamps that I have. I think that it will all work out O.K. Grant.
2 years 11 months ago #232136
by Ray54
The vegetable business not many years ago used a lot of that type clamps. Not being in that business I don't know about today, but real hard for me to think it is not around. I put diamond bar in a google search and there where a lot of hits.
I might even have some in the junk iron pile. I know there is one on my liquid fertilizer applicator. Mine are clamping coil spring shanks in the 1 inch size. In the old days always wanted the 1 1/4 size as far more robust. But have picked up enough I inch shanks I will never break them all at this stage of my life.
2 years 11 months ago #232154
by GrantJ
I doubt that I will ever break one of these beasts. I think that they are over strength for my old D4 6U. They came with the old steel wheel Killifer that I bought, but it was an estate sale and I think the guy gave me everything that he thought went with it. I have 5 plow type 1 inch bars and the two ripper bars that will soon have a 1 inch area for the clamp. I will use the ripper far more than plowing, since I am basically clearing roots and brush to expand my hobby orchard. I will also be doing some road making for fire protection and logging access. I am going to do a separate post to identify the grader that came with my D4. No name plate and I am sure it is not a Cat grader, but it is plenty beefy for what I want to do. Thanks, Grant.
Time to create page: 0.371 seconds
