Vintage Caterpillar tools
Thank you received: 341
2 years 11 months ago - 2 years 11 months ago #231964
by edb
scans below may help.
With the grease valve shown below I believe that the text should read "4.5 psi to 5.5 psi" and not the "450 psi to 550 psi" or else the use of the low pressure relief valve would not be needed--from personal usage experience the pressure relief feels like 4.5 psi to 5.5 psi on the handle as the lube comes out the RV with little very handle down pressure. In fact sometimes one wonders if any grease/oil went in at all.
Last edit: 2 years 11 months ago by
edb.
Fat Dan
Thank you received: 63
2 years 11 months ago #231967
by PhilC
Hello All
Does anyone know what this dial indicator set is used for?
Regards
Phil
Thank you received: 620
2 years 11 months ago #231991
by edb
Hi PhilC,
is there a group part number on the box?
I feel I have used this group way back for dynamic rack readings--which engine I do not recall but by the two bolts and shape of the rod end of the bar it may be D300 series engines--Cat came out with many variations of tooling in this era for the same engines but in different applications--the different tooling and application accessibility often dictated which one was used, and some tooling was easier to use as designs changed.
Fat Dan
2 years 11 months ago #231992
by PhilC
Hello Eddie
The numbers in the auction are 9S215 Dial Indicator & 9S7350 Bracket.
If its for the D300 series engines I might have to add it to my collection:)
Regards
Phil
Fat Dan
Thank you received: 153
2 years 11 months ago #231993
by rax200
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
2 years 11 months ago #232002
by edb
Hi rax200,
alas my web blocker says that is a malicious site so I cannot get to it.
Thanks,
2 years 11 months ago #232003
by rax200
Hi All,
I have a couple of more tools to add to the list,
9B2089 early injector socket to remove and install.
3B6780 socket to remove the special nut on the layshaft on D4's
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
Deebo
Thank you received: 104
2 years 11 months ago #232146
by Deebo
Just ordered a NOS 3B6780 from Florin, thanks for the pic, now I know what to expect!
2 years 11 months ago #232273
by rax200
Hi All,
here is another too that I picked up a few months ago, it is for removing precoms chambers from press in type heads,
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
Deebo
Time to create page: 0.413 seconds
