What size bolts fit the track roller frame to attach a front bulldozer.
2 years 11 months ago #231541
by oscar
What size bolts fit the track roller frame on a D4 7U. The holes are already treaded.
Thank you received: 620
Thank you received: 387
2 years 11 months ago #231564
and smear them lightly with grease or anti seize so they tighten easily and properly. after cleaning those threads well. its no fun getting things half on and a bolt breaks or fails to tighten properly thats how things get smashed later. ive seen a few machines needing costly repairs be cause bolts were not properly tight or had worked loose.
Thank you received: 20
2 years 11 months ago #231565
by 8C 361
I found those unused holes plugged with cork to protect them on some tractor.
Again proper cleaning and possibly re tap.
Seems like I have a 5J that has the holes marked but not drilled nor tapped. Not nearby so can't say for sure
Thank you received: 409
2 years 11 months ago #231566
I did all mine a couple of years ago. Only 3 out of 16 came out by unscrewing. The rest had to be drilled or blown out. I retapped them, added some copper anti-seize and fitted 16 new lug bolts. I had to remove the blade mounts a couple of weeks ago to get some machining work done and they undid very easily.
2 years 11 months ago #231896
by oscar
Thanks for your help. I got the bolt and clean all the threads and mounted the braces. I’m going to use Abe gee rear mount pump for now, but I’m looking for a cat 44 front mount.
Any help will be appreciated.
Thanks Again
Time to create page: 0.147 seconds
