D4 &U Air Cleaner Seal
Thank you received: 13
3 years 4 days ago #231437
by blwatson
Would any one happen to have the most current part number for the the air cleaner seal, old number 7B5716? Serial # 11867 D4 7U.
Thanks in advance.
Bruce
D47U #11867-1950
Idaho
Thank you received: 387
3 years 4 days ago #231445
is it the gasket were the housing bolts on or the sealing washer for the precleaner. is yours a oil bath or cartridge type.
Thank you received: 341
3 years 4 days ago #231449
by edb
It is the seal where the oil cup mates to the main body--my 6U1-up P/Book shows the same 7B5716 seal, bracketed with the P/No of the main body of the A/Cleaner.
If the P/No updates then Cat Parts Dept should have the superseded number in their system.
When I locate my old Cat "O" Ring book I should be able to give you the dimensions if you are purchasing aftermarket.
3 years 4 days ago #231452
by blwatson
Mine is the oil bath type and is the one that Eddie mentioned. I was not sure if Cat parts would have changed the part # or not. Some of the new guys at the parts desk do not always seem to be too helpfull with the older parts. I will check with them. I did find some on ebay and some other after market sites that I will check out also. Thanks guys.
Bruce
D47U #11867-1950
Idaho
Thank you received: 153
3 years 4 days ago #231458
by rax200
Hi Bruce
I will have a look when I get home for the number
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
3 years 4 days ago #231463
to my knowledge ours doesnt have one. dont remember seeing one when i drained the oil cup last time. will have to look into that. any hydraulics joint should have a suitable oring. take the bowl with you so you can get a suitable size.
many industrial suppliers dont keep made orings anymore but instead carry lengths of oring material or the oring maker kits as the material comes in standard thicknesses and fairly standard materials the reason being cost and they do deteriorate with age why have a heap of inventory you sell little of.
3 years 4 days ago #231468
by rax200
Hi Bruce,
the part number 7B5716 is a good number for the air cleaner.
I dont know where it goes but I say inside as mine in the later air cleaner had 2
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
3 years 4 days ago #231471
by edb
knew I saw this recently--scan below tells of the seal position--despite how it looks in the picture the "O" Ring goes around the outside of the upper body up against the step that the bowl clamps against--the "O" Ring is shown part assembled/fitted to the upper body and a loose section is hanging down--you need to blow up the pic to see what I am saying.
Thank you received: 409
3 years 4 days ago #231472
Hi Eddie, I guess we can assume the reason Cat added the o-ring - was there guidance given to retrofit them to prior tractors that have the same type of air cleaner arrangement?
3 years 4 days ago #231473
by blwatson
Thanks all for the info. The last time I serviced the air cleaner I just reused the old O-Ring, looked to be in good shape. I should have known better and replaced it because it has always weeped a bit of oil. Never did get it to seal good. Not sure if it was original cat issued or not but seemed to have a bit too small of a diameter to seal properly. Has any one had good luck with any of the after market ones that are available on line?
Bruce
D47U #11867-1950
Idaho
