D2 sprocket removal minimum requirement
Thank you received: 409
3 years 4 weeks ago #230870
Restore, if you cut the frame, how much do you take out, and how much do you have to lift the frame with the cut made?
Thank you received: 42
3 years 4 weeks ago #230872
by restore49
933 loader so slid straight out on greased steel plate - front roller was on the ground from frame rail breaking so no need to separate track.
3 years 4 weeks ago #230874
by restore49
All excess material no structural affect. Around 1" from back of tube at deepest part of cut. Bob
Thank you received: 251
3 years 4 weeks ago #230875
by juiceman
I could envision someone cutting a section of the sprocket and welding it back together to make a shortcut. JM
3 years 4 weeks ago #230876
by restore49
My cut with no structural effect could also be made to outer frame section leaving in place - so other than getting the track to clear nothing else would need to be done. The section could be welded back in after the fact to hide the change.
3 years 4 weeks ago #230884
That's what I was thinking Bob, maybe a bolt on the backside for easy access next time! : ) I'll inspect my unit when I'm out there next. Sure would be easier than messing around underneath. I'd only do this though if I needed to replace the sprocket before winter. I'm anticipating no more than 50 hours with it on the floppy sprocket before I pull the track frames anyway - would that be enough to damage the shaft splines? I'm assuming the sprocket hub is softer than the shaft.
Now, who has a worn-out sprocket with good splines?
Thank you received: 46
3 years 4 weeks ago #230891
by dpendzic
Neil--to take the slop out of my sprocket/shaft a had a large washer machined and installed that between the sprocket and nut and torqued the nut up real tight to take any play up
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
Time to create page: 0.158 seconds
