What model grader am I looking at here?
Thank you received: 16
3 years 1 month ago #230710
by Mangoman
Hi folks,
I have a good friend that looked at an old grader the other day. I haven't seen one like it before but I'm no expert by any stretch. It somewhat looks like a No.11 but the drawbar is channel and looks older. It also has a D4400 rather than the D6600. The motor unit looks to be a different shade of yellow. Any chance the D4400 was retrofitted? It just looks a little unfinished how it is installed. When I did a little research, I found out about a No.10 Tandem Diesel grader. Could this be one of them? Thanks friends.
Mangoman
3 years 1 month ago #230712
by Eds-oldiron
The serial number is stamped on the brass tag above the left front wheel in your photo, on the web of the frame channel. That will ID it.
3 years 1 month ago #230714
by Mangoman
Yes Eds, I will refer my friend to check. He didnt get that info but that will positively identify what we are looking at. I just thought I might get some preliminary info from more knowledgeable folks. Thanks
Thank you received: 142
Thank you received: 341
3 years 1 month ago #230721
by edb
the fuel filter is the standard edge type brass plate stacked canister that are a cleanable elephant strainer of the day---see scan below from a D4400/D4 fuel system.
3 years 3 weeks ago #231092
by Mangoman
So, my friend got back out to look at the grader. From what I can read it says 9F1616TS. What does TS mean if that is what I am reading? From what I can see 9F means Auto Patrol No.10 It also looks like there were No.10 graders with the D6100 3cyl as well as the D4400? Anyone have a better idea of the actual year of this thing, and also about the "TS"? Thanks!
